FTA Sat Out - How Far Can One Run Coax To Another Receiver?
Stargazer
16,569
342
Western WV
How far can you run a coax wire from the satellite out port from one receiver to another? I want to run two receivers off of one dish that only has a single output lnb.
How far do you want to go ? If it were a long ways, I'd get a 500 ft roll of coax, put fittings on both ends and connect it up in the same room. If it works there, it'll work all stretched out. I'd expect that it somewhat depends on how far the original run of coax goes to the lnbf. [edit] I'll guess at maximum length from lnbf ~ 250 ft ] Let us know.
unknown sat ?
BYU Audio Problem
