I wonder if some manufacturers ever try to use/install the products they manufacture?
Products can be manufactured to precise accurate specifications.
And if there was ever anything which requires precision in aiming, it is a satellite dish. With G10, adjusting your dish up/down or left/right to the borders of this ---> O can mean poor or no reception of some channels. You need to point your dish to the center of this O.
Very fine adjustments are needed. Pretty much essential to have a threaded screw or turnbuckle to adjust fine dish elevation and an accurate elevation scale.
I see a lot of people following installation instructions and getting frustrated because they can't get any satellites.
Seems to me this is an area the manufacturers would want to work on and improve. It would mean more sales. They could have products which meet certain specifications and have an "Easy dish installation seal of approval" (or whatever). Products such as...
-Dishes with highly accurate elevation scales and precision adjustment screws.
-Positioners with highly accurate elevation scales and precision adjustment screws.
-Receivers which also include a third signal level bar which would indicate any satellite signal like a coax attached signal meter.
-Receivers which include dish pointing software.
Then the receiver could have a step by step installation screens which could also help by moving the dish back and forth automatically during installation, then telling you what to do to get more satellites in the arc.
Example: Help you find the first south satellite...
1. enter your zip code.
2. Set dish to xx elevation, set positioner to xx elevation, point dish xx direction.
(then dish moves back and forth - no sat found.)
3. Receiver tells you to turn positioner screw 1/2 turn clockwise.
Etc.
Receiver has you keep turning screw a certain amount and then tries to find sat. Goes so many screw turns a certain direction, then has you go back to beginning and try opposite direction.
Then after south sat found, moves dish back and forth and sees how many sats found in arc. Then gives step by step instructions (along with moving dish back and forth automatically after each adjustment) to help you adjust dish to arc.
Another idea would be a very easy to install positioner/dish combo which has a motor not only to move east/west, but two additional motors; one to adjust dish elevation and another to adjust the arc. Then the positioner could automatically adjust the arc for you. All you would need to do is point the dish south, then rotate the positioner on the pole a little east or west as told to do by the positioner/receiver. (Also include accurate marking stickers to apply to mounting pole - i.e. positioner would tell you to rotate positioner on pole 1 mark east or west, then try to self-adjust to arc again.)
Etc.
