Need help - can't get locked on to a satellite. I have a Coolsat 6000 premium receiver, a Stab HH90 DisEqC 1.2 rotor, a FortecStar FC-90 dish and a InVacom Quad Polar 40mm horn LNB. My zip code is 55912. I've been trying to lock in on satellite IA 5 97.0 W using the motorized setting with the following settings:
Frequency (1) 11,749
DiSEqc motor USALS
Move Stop
Limit Motor control
Sat. Degree 097.0 W
Antenna Position 093.0 W/ 043.7 N
The best I an get is a Level in red of 87% and Quality of 6 - 8 % using a dish elevation of 34 degrees.
I also tried connecting the antenna wire directly to the LNB and then moving the whole unit oin the pole and changing the dish elevation gradually from 34 up to 40which then reduced the Level to the 70's.
Should I be receiving some sound on the TV? I am not getting any sound.
I checked the pole yesterday and it is perfectly straight up and down.
Sure would appreciate any suggestions. Thanks. Dick
DiSEqc motor USALS
Move Stop
Limit Motor control
Sat. Degree 097.0 W
