$175 SHIPPED INSURED CONUS
PAYPAL preferred.
I have taken good care of this reliable receiver. It has been well ventilated. Never stacked. I've upgraded recently, so I no longer need it. It works perfectly.
No audio pops or crackles. Pristine condition. Absolutely no scratches, scuffs, or dents. Lens is crystal clear. Solvents were never used. Even the input/output jacks/posts are without scratches because I rarely switched things around. As a result, all posts are firm.
Remote was never used. (I've used only Harmony remotes).
Original manual and paperwork included.
Details copied and pasted:
PAYPAL preferred.
Features
32-Bit Processor: This receiver employs a 32-bit processor, providing precise surround decoding for Dolby Digital, Dolby Digital EX, DTS, DTS-ES, DTS Neo:6, Dolby Pro Logic, and Dolby Pro Logic II, plus Sony's Digital Cinema Sound modes.
7-channel Amplifier: This receiver drives 100 full-bandwidth-rated watts x 7 channels of power.
7.1-Channel Decoding: This unit is equipped to decode 7.1-channel signals. In addition to the standard 5.1 channels, some movies now encode surround back channels. The surround back channels improve the realism of sounds panned across the rear soundstage.
Surround Modes: This receiver incorporates a wide variety of surround modes to bring you maximum enjoyment from your audio and video software. The surround modes include:
Dolby Digital
Dolby Digital EX
Dolby Pro Logic
Dolby Pro Logic II (Movie and Music)
DTS
DTS-ES (Discrete 6.1 and Matrix 6.1)
DTS Neo:6 (Cinema and Music)
Cinema Studio Ex. A (Digital Cinema Sound)
Cinema Studio Ex. B (Digital Cinema Sound)
Cinema Studio Ex. C (Digital Cinema Sound)
Hall
Jazz Club
Live Concert
Headphone Sound Fields: When headphones are connected, you can select the following sound fields:
2CH: outputs the sound in stereo. Standard 2-channel sources completely bypass the sound field processing. Multi-channel surround formats are downmixed to 2-channels.
Direct: outputs the analog signals without digital processing
Multi 1/2: outputs the analog signals input to the Multi-channel input jacks
Theater (Digital Cinema Sound): allows you to experience a theater-like environment
Analog Direct: Analog direct mode bypasses all digital signal processing for maximum audio purity from any analog source.
Sound Field Customizing: Depending on the Mode selected, you can adjust the following parameters:
Front Balance: allows you to adjust the balance between the front left and right speakers from L+16 to R+16
Center Level: the level may be adjusted from -10dB to +10dB in 0.5dB increments
Surround Left Level: the level may be adjusted from -10dB to +10dB in 0.5dB increments
Surround Right Level: the level may be adjusted from -10dB to +10dB in 0.5dB increments
Surround Back Left Level: the level may be adjusted from -10dB to +10dB in 0.5dB increments
Surround Back Right Level: the level may be adjusted from -10dB to +10dB in 0.5dB increments
Subwoofer Level: the level may be adjusted from -10dB to +10dB in 0.5dB increments
Dynamic Range Compressor: allows you to compress the dynamic range of the sound track. You may select standard or maximum compression.
Note: This feature only works with Dolby Digital sources.
Effect Level: the "presence" of the surround effect may be set to Minimum, Standard, or Maximum
2nd Audio Output: This unit is equipped with stereo RCA jacks to send a stereo audio signal to a receiver or amplifier in another room. The same source or different sources may be played in the main room and the 2nd room. Only signals from components connected to the analog input jacks are passed through the 2nd audio output jacks.
Note: If "2nd Room" is set to "Source" and you select the Multi CH 1 or 2 input, you will get no output from the 2nd audio jacks. Additionally, you cannot select Phono as the second audio source.
Dual Multichannel Inputs: Although this unit features built-in Dolby Digital, Dolby Digital EX, Dolby Pro Logic II and DTS processing, it also has a 5.1 multichannel input and a 7.1 multichannel input for use with external multichannel decoders.
Station and Source Naming: Each preset station and program source may be given an index name of up to 8 characters. For example, two VCRs can be displayed as 8MM and VHS.
Sleep Timer: The unit may be set to automatically turn off after 2 hours, 1 hour and 30 minutes, 1 hour, or 30 minutes.
Dimmer: You can choose from 3 levels of display brightness.
Remote Control
Learning/Multibrand Remote: The supplied remote is pre-coded to control Sony A/V equipment and most brands of CD players, DAT decks, MD recorders, tape decks, LD players, video CD players, VCRs, DVD players, TVs, DSS receivers, and cable boxes. In addition, this remote can learn up to 80 infrared commands from remotes of other components. A single-line LCD at the top of the remote shows the source currently being controlled. The LCD has an amber backlight that stays illuminated for 3 seconds after a new source is selected.
Macro Play: Up to 2 macros, each with a maximum of 10 steps, can be stored in the remote, allowing you to perform a series of operations at the push of a button.
Inputs and Outputs Notes
DVD Digital Input: The digital audio connection assigned to the DVD audio and video inputs is a coaxial digital connection. Although the optical digital inputs on this receiver can be assigned to various sources, they cannot be assigned to the connections labeled "DVD". If the only digital output on your DVD player is an optical output, you may assign one of this receiver's optical inputs to the "TV/SAT", "Video 1" or "Video 2" inputs, then you may use those connections for your DVD player. If you want to route component video from your DVD player to this receiver and your DVD player only has an optical digital audio output, you'll need to connect your DVD player to the TV/SAT inputs of this receiver.
Speaker Outputs: There are binding post connectors for the left front A, right front A, left front B, right front B, center, left surround, right surround, left surround back, and right surround back speakers. The binding posts are not 5-way because a plastic collar prevents their use with spade lugs.
Control A1 II: The Control A1 II Control System was designed to simplify the operation of audio systems composed of separate Sony components. Control A1 II connections provide a path for the transmission of control signals, which enable automatic operation and control features usually associated with integrated systems. This receiver has a single Control A1 II mini-jack output.
Control S: This receiver has one Control S mini-jack output and one mini-jack input for use with compatible Sony components.
