Single Polk Monitor 40 Bookshelf Speaker (not a pair)
-Brand New - never touched a speaker wire
-I am using it's partner as a center channel sspeaker in my HT, and it sounds incredible. Full, rich lows; clear mids; airy, smooth highs.
-It can be used as a Rear Speaker in a 6.1 system, or as a Center Speaker in a cabinet/TV Stand that cannot fit a traditional large center channel speaker. (Due to its symmetrical design, it can successfully be placed on its side.)
Specs:
-Mid/Woofer 2 - 5-1/4" Diameter (13.34cm)
Dynamic Balance Bi-laminate composite cone driver, magnetically shielded
-Tweeter 1 - 1" Diameter (2.54cm)
Dynamic Balance Silk/polymer composite dome, magnetically shielded
-Frequency Response 47Hz - 25kHz
-Lower -3dB Limit 57Hz
-Upper -3dB Limit 24kHz
-Nominal Impedance 8 ohms
-Recommended Amplifier Power 20 - 125 w/channel
-Dual (bi-amp) 5-way binding posts
-Cabinet Size 15-3/4" H x 7" W x 12" D
$85 shipped (US lower 48)
(Orig MSRP $349/pr, currently $150/pr at NewEgg Newegg.com - Polk Audio Monitor 40 Black Two-way bookshelf loudspeaker Pair)
Specs:
