Here is the issue I am having. I have BEV service that I am receiving in Michigan, well within the footprint of both the 91 and 82 satellites. I have had the service for around 10 years and never had issues with signal strength or transponders cutting in and out. About 6 months ago the signal from all 91 and 82 transponders started fading in and out. It gradually got worse and worse until it was no longer watchable. I lose the signal and get the "Please standby for the satellite signal" message every 10 seconds. I had a Dish Network 500 dish with a dual lnb. I have two BEV 9242 receivers that are probably around 6 years old. Here is what I did to try and detect where the problem was. I put up a new 500 dish and a new dual lnb - didn't work. I ran a new cable directly from the dish to the receiver (tried both receivers individually) - didn't work. I then thought that maybe the 500 dish was no longer big enough to catch both signals (because of the reported satellite wobble), so I bought a new Winegard DS 2077 30" Dish Network Satellite Dish (DS2077) to use in conjunction with the 500 (pointing one at 91 and one at 82). I tried pointing the new 30" dish first to the 91 satellite. I get great signals on all transponders (75-90 range) but it takes about 5-10 seconds to lock onto the transponder and when watching a station the signal still cuts in and out. I can't find a signal at all from the 82 satellite, probably because it is taking so long to lock into a transponder. At this point I have no idea what to do next. I figure it can't be a problem with the receivers, since I am getting the same issue from both (unless both are corrupt, damaged or out of date). Does anyone have any idea if this is a dish issue. lnb issue or a receiver issue or what I can do to fix the problem? Do the receivers need a firmware update? It says my software version is V195.
Very Frustrated - Missing Olympics on CBC.
Thanks!
Thanks!
