I've been out to one of my Buds twice already this winter to re-level the pole... Each time it had moved maybe half a degree. Never have had to do this in the past except maybe once a month or two after initial installation. Almost no snow cover this year in my area, and lots of cold (-30 type temps), and lots of wind! Not sure if it is frost heaving or wind moving the piles around because of loose dirt-to-cement contact... It's also been VERY dry.
My setup used three piles about 10' deep (14" diameter) that stick up about a foot above the ground, using 1/2" threaded rod sticking out of the piles to attach the dish tri-pod/mast assembly. Luckily I can adjust using bushings between the mount and the pile; adding or removing bushings below each mount and then tightening up the nut again to level it.
Was out working on it last night after discovering very poor signals on some of the TPs on 97, 101, and 103 I often watch in the evenings. At least it's been a bit warmer last few days.
Anyone else having issues with frost heaving etc? Been a cold dry winter up here!
