Freq Differences
daveplot
18
Salisbury, MD
I finally got my dish pointed correctly and did a scan of IA-6. Comparing what was found with what is at lyngsat, there are a few differences.
For example ABC ABSAT was found on 12051 h and v, where lyngsat has it at 12053 v and 12058 v. There are differences like this on the other channels too.
Is there something wrong with one of my settings?
Also some of the channels have $ before them, what does that mean?
Thanks.
No you are fine, all LNB and receivers are slightly out to each others (brands) then add to that the blind search and it sometimes stops short of the exact freq.......
The $ means that the receiver thinks it's scrambled. Sometimes you'll see this on channels that are in the clear -- I don't know why. More often, you'll get a solid quality signal and a blank screen, which means the scrambling is working. :)
daveplot...I just recently figured that out with my Satwork 3618. The transponders are 10Mhz higher on lyngsat and the symbol rates are 5Mhz lower on there. So now I know that I have to add or subtract to find out what they really are. Now its second nature when I look at the frequency I just convert it in my head. Thanks to PSB and others, I finally figured that out!
yep. It all depends on your setup
When I smart scan G10, it has been known to scan in a TP as
11717, 11718, 11719 or 11720 depending on the day :)
The $ says its scrambled, but may not be. There are some christian channels on AMC4 that have a $ in front, so when you scan for "FTA Only" it wont pick it up. But these come in at a 99 quality if you say "scan all" :D
Signal levels for comparison
Water and Electricity!
