..Motorizing these beasts is a challenge.
They have a fixed mount.
You either need to come up with a standard BUD mount to put one on...
... or maybe do what Pendragon did and put it onto an AJAK 180.
But (hopefully) you all saw what Linuxman did with his (look it up!).
It made a magnificent multi-satellite fixed-dish Ku system....
Is that all?I drove over there for a 1.2 about a year ago.
Might be time to go again!
It's about an hour & a half east....
I drove over there for a 1.2 about a year ago. Might be time to go again! It's about an hour & a half east....
He and several others who have rigged up mounts for offset dishes, have built in a ~22° down-tilt to compensate for the up-look of the dish.Thank you for the reminder of Pendragon's Prod/AJAK conversion,
I just found that thread and got some great ideas there.
Your AJAK or other mount might need extra elevation travel (downward) if you are up north.Polar mounts have the declination adjustment as part of the mount (though I am trying to see the declination adjustment on this mount). Maybe that is why the op drilled new pilot holes in the top support?
Set the Declination Angle based on your installation location then adjust the elevation angle to compensate for the offset dish angle (Offset Angle + Declination Angle + Polar Elevation setting = the Actual Satellite Elevation Angle). The dish will track the arc in the same path whether prime focus or offset design.
Is that all?
I go to lunch on weekdays with a guy who drives an hour & a half to work each day!
I just coughed up $100 for one of these. Kinda goes against the spirit of FTA being free like my other 12 dishes were.
But now that I have it home I'm overwhelmed at the polar mount project. Can you guys put up a few pictures or links of the ones you have done?
