Fox sure likes that mpeg2!
teamerickson
1,716
El Dorado Hills, CA
It's a shame that Fox studios continues to favor the super old mpeg2 codec to show off the so called technological advantages of Blu-ray. Isn't Blu-ray supposed to take the movie experience to the next level. It seems this is just a standard DVD at higher bit rates.
Fox brought us widescreen 480. Took them a long time to move up. Don't hold your breath.
I take it you havn't seen Kingdom of Heaven in MPEG 2. It WOULD BLOW YOU AWAY
only to an extent. It is not flawless.
I am stating that MPEG 2 still looks as good as VC-1 or AVC, and my proof is KoH. I really do not care which codec they use so as it looks amazing.
I believe it would look superior on VC-1
"There are a few flaws, however. As the movie fades in from the opening title credit, some posterization is plainly visible, a problem that recurs during other slow fades. Low-amplitude edge ringing is also present during sharp contrasts repeatedly throughout the movie, lending some scenes a harsh "digital" texture. Fortunately, both issues are relatively minor and rarely distracting" - DVDtalk
Bob, VC-1 is not necessarily a superior compression technology. It is only superior in that it can produce some very good PQ when using low bitrates (hence the reason it is the choice of HD-DVD). However, both Mpeg2 and Mpeg4AVC can produce the same PQ although with a requirement of higher bitrates (hence the reason for continued use by BD). I personally prefer higher bitrates as I believe you can get better PQ and soundQ from higher rates. Someone more techie than I would have to explain this but I believe it to be true. Just look at your cable and satellite feeds -- more bitrate better PQ and SQ and I believe this to be true with HD movie authoring.
On another note, (credit to Mr Kotches) M$ continues to tweak VC-1 encoders and continues to get great results from it. However, I believe that this is a prelude to M$ providing downloadable movies for the 360. And at the limited rate of our poor internet (very slow compared to other countries) system I can see M$ using very low bitrates for HD movie viewing from the internet to the point it becomes like DirectTV HD -- HD-Lite anyone?
It would be better to have VC-1 at MPEG-2 bit rates... But, they tend to try to save by lowering the bit rates more than advanced compression can compensate.
Down under Blu-Ray already the winner?
Does Universal hold keys to the end?
