I've temporarily set aside the motor on my 90cm GeosatPro dish, since the balcony is tilted and I can't get shims under the NPRM nicely to keep the pole plumb. I switched back to a multi-LNBF setup with 103/97/91, which works well. Six-degree spacing is as close as I can get with the Maverick and GeosatPro LNBF's I have right now (they're touching each other and physically can't get closer). I'd like to try for four-degree spacing, hopefully 103/99/95/91. There don't seem to be too many LNBF's that would allow for this. I know SatelliteAV has their bullet LNB, but I'm not about to pony up $45ish per LNB.
What would be a relatively reliable way to get four-degree spacing on a 90cm dish? I recall seeing threads years ago on here of people cutting away some of two LNBs and gluing them together, but I'm not sure about going that route. Murphy's Law seems to follow me around... Has anyone tried out one of these guys? Would it give enough gain to be fairly reliable on US birds? Maybe a couple carefully-placed World Direct LNBFs?
