Fortec Lifetime Ultra Problems
Wholeshoe
354
All
My Fortec Receiver has changed all of the satellite settings in its antenna setup menu to weird things. Like the type LNB, the Disecq setting, and the LO setting. If I go change them it works fine for a few hours and then they change on me again.
This happened before and I did a factory reset and it has been fine for a month now but it acted up again today.
Anybody got any suggestions?
Wholeshoe
Do a factory default...... Everytime you add a new satellite go into that satellite and "Edit/TP." Delete every TP. on the satellite bar one. Then do a blind scan of the satellite. If you do this with every satellite as and when you add it (remove all but one TP.) You should be good to go, I had the same problem and its never happened since I started using the above tip.
Good Luck!
Thanks for the tip,
Is there a certain tp that I have to leave or just any old one?
Wholeshoe
If you do a lot of blind scanning, delete the TP's in those
The 3 I always seem to eliminate frequently are SBS6, AMC9 and IA6
Pansat HC - Info Request.....
LNB problems?
