more info
More info never hurts.
And, sometimes correct statements, taken in a vacuum, are misleading.
Prime focus dishes are true so 45 degrees is a legit 45 degrees There is no offset
Taken alone, this is not wrong.
There is an offset for Prime Focus dishes.
It's called "Deviation", and where I'm at it comes to 6 degrees of deviation.
Well, for a BUD, there is a declination adjustment, and for parts of North America, 6º sounds pretty good.
This is not wrong, from a BUD-user's standpoint.
I believe deviation is only used when motorizing a dish.
Since this dish will be manually adjusted only the elevation needs to be set.
There's a lot of truth in this one, too.
Everybody need declination, but for many of us, it's already built into our Az/El calculators, so we ignore it.
So, if we are talking about manually adjusting the fixed Fortec 6' on it's Az/El mount, any old Az/El calc will give us all we need.
If we're using the Fortec 6' (or any BUD) on a Polar mount, (which implies we're using a motor), then the declination must be adjusted manually.
If we have a little dish on an HH90/SG2100, then
the motor bracket is elevation, and what you would call
the elevation on the dish mount is the real declination.
That's why I think so many people have trouble adjusting the little motors -
The current wisdom uses incorrect and confusing terminology for the two interacting adjustments.
By just calling it what it is, I feel it'd be a lot easier to understand.
film at 11
