How do I force my Dish receivers to use satellite 61.5 and ignore 129 since 129 is flaky here and 61.5 is solid?
Dear Old Corps,
yes I have 1000.2 LNBF,
and I did cover up the correct 129 LNB,
and I did run the Test,
and it did warn me that I had now had fewer satellites than before,
and I did accept that,
and it did download a new channel guide,
AND
ALL my HD channels were dead!
They still appeared on my channel guide list but they were non functional.
I went through the entire guide from the 00-XXX numbers to the top of the list at 9902.
I tried every HD channel on the list.
Not a single one of them worked.
Dear Old Corps,
AND
Finally solved the 61.5 issue.
I happened to have a perfectly good DPP Quad LNB so I originally used that to pick up 61.5. That is when I was able to pick up some HD channels but not the ones I really wanted. For those who don't know, the Quad has two heads and 4 outputs.
I called Dish and the tech on the phone told me that he didn't think the Quad would work for this purpose. Indeed the Dish instructions specify either a DPP Single or a DPP Dual to pick up 61.5. So I bought a Dual (one head with two outputs) and it works!
My 129 head is now wrapped in aluminum foil and I'm getting all my HD channels from 61.5 with no fade out.
yes, that may very well be, however it usually won't work (and isn't supposed to) on the extra LNB input on a 1000.2 LNB or a DPPTwin. For one, the power requirements are a little too high, and for another, you are adding a switch, in a situation that already has one.My dish 500 pro quad works great for 61.5. It makes no difference which output I connnect to. The only difference with outputs is aligning the dish for best signal.
Ron
