Hi all, I want to see if I can hit Telstar 12 at 15W. The elevation will be quite low for me so in an effort to get the dish to point low enough I decided to try the inverted trick. It was really very easy to flip the clamp part of the mount over then turn the dish upside down. It looks like it might work. I have LOS just behind the BUD and just over some far away trees. After looking at the setup I can not wrap my brain around the skew. Does it get reversed when the dish is upside down?
I will need almost 60 degrees of skew but will it be clock wise like it would when mounted right side up or will it be counter clock wise?
Guess I can try both?
Should be a fun project for this weekend.
Thanks in advance for any tips on the inverted skew, DC
