Gents;
Just received a 76cm Winegard dish (thanks to Tom Taylor - fast, friendly and inexpensive: great job!!) that I hooked up to my Pansat 2300A. I assembled the dish and installed it outside on the same mast and arm that my previous Dish500 antenna was using (I reused this b/c I knew that that mast was plumb and vertical).
I aimed the dish using the following coordinates that I got for Telstar 5 from the SatFinder program: AZ 220.4, EL 41.7 and SK 23.1 (I am in Richmond, VA). I connected a nice thick 25' run of high quality RG6 (Radio Shack Gold quad shielded cable) to my reciever and went to the "Antenna Setup" screen on my reciever to set up the T5 bird. I set LNB Type to "Standard" (since I am using a standard LNB), the frequency to "10750", 22khZ to "Off", DiSEQ to "Off" and Skew to "23". The signal strength on the setup screen is showing 94% (almost maximum) but the signal quality is 0% - when I attempted a satellite scan, the reciever found nothing on T5!!.
So, what am I doing wrong?? Do I have the right settings for my receiver? How do I know if I am aiming correctly? I don't understand the "Skew" setting in the antenna setup screen in the receiver - if I manually rotated the LNB to 23 degrees (which I did), do I still need to set the Skew to 23 in the recevier? Did I turn the LNB in the right direction when setting the skew (when facing the dish, I turned the LNB clockwise until it was at approximately 23 degrees - should I have gone counter clockwise?)? if anybody can help guide me through this, it would be greatly appreciated. The receivers operators manual is almost worthless - it has a terminal case of Engrish. So, all y'all FTA experts, please weigh in with what you think I need to do to get this system up and running. Thanks!!
