Yeah I found this whole thing kind of weird. How are you supposed to keep different patches on a thumb available for updating. You would think that the coders would've allowed for that!
Putney,
In this instance I have created a file system where I download the individual firmwares into a file folder that is named with the version number of the release. I retain all the files in this manner so that I can differentiate between them fairly easily. If I need to apply (load) any one specific file, I apply the rules necessary for that individual file as appropriate.
On your Windows PC, if you right click on the file and go to properties, then select details, you can get the exact file name of patch.bin.
ACWXRadar
I am referring to the long file names for "daily updates" at
AZBox Daily Snapshot.
Knowmiddlename,
I personally don't want to set my AZBox up to automatically update my firmware files. I want to have control over the whole thing. I don't exactly trust everything out there and if I test something, I want to be the one responsible if it screws up. I like to hear from others a few comments regarding a specific firmware application first, maybe give it at least a couple of weeks before I try it in case there is a bad bug.
I've never renamed any of mine and they loaded just fine...but then again I only keep the current software on the thumb drive
Ice,
You will have to make some adjustments with the newer software, otherwise it may not load from a USB drive. If they release it officially and offer it via the official URL, then I think the version will appear naturally and you can download it from there directly without any problem.
I was OK up to version 0.9.3686 and loaded all versions via my USB thumbdrive in the same manner. At or after version 0.9.3686, something was altered.
This is not a really bad thing as nothing will become fouled up as I mentioned earlier. Simply, you will know that it is not working properly as the AZBox will simply not realize or recognize that the patch is present. It will simply skip over the patch and reboot.
The receiver should find the patch file and stop somewhere during the reboot process and tell you that it detected a new patch file and give you some options before continuing.
EDIT: I want to ensure that everyone realizes that no harm or foul will come of your AZBox if you do this incorrectly. The AZBox will simply not find the new file if it isn't named correctly. So you can play around with the file name until it works for you, when the file name is correct, it (the AZBox) will play ball with you.
RADAR
