I received my Quantum DVR system yesterday and set it up. I have to say that I read the forty something pages at DSL Reports while waiting for my system.
I did the 2 VMS and 2 IPC set u so I would have 12 tuners and 2TB
I followed the installation instructions .........
You must disconnect your previous boxes completely before the install.... they dont play well together.
You start with the VMS server/s - one at a time and then the IPCs.
the install went very smooth. The only place I went wrong was that I did not choose "manual" when installing the first IPC and it selected the wrong VMS. Not a problem, after the install was done I changed it.
It booted up and everything seemed pretty normal as far as speed and function. A lot of people have said they see an improvement in the picture - more on lower end sets. I cant say for sure if I see it. I think I see more saturation but not a difference in pq.
About two hours after the install was done the unit I was watching started with audio drop outs on the channel I watching. In the process of trying to change channels the box would not respond and I had to unplug and reset the box. It took a while for it to reset and it was ok for what little time was left before I went to bed.
So, this morning I looked up a fix I remembered seeing for the audio drop outs. It was an issue mentioned on DSL reports. I did the fix and so far.... knock on wood....... it hasnt happened again. However, the problem with the box responding did happen again.... when my husband turned on the upstairs box later this am.
I started thinking that maybe it had something to do with having that box set up on one VMS and then changing it. So I did what they called a COLD reboot which reboots this VMS and then reboots the IPC as well. So far there have been no problems since then.
One of our biggest things before was a shortage of tuners for recording and that was my reason for upgrading. If we run out of tuners now I'll know we have no lives!!!!
