I have an install sked for 2/25. I'll be getting voice and internet 20/5.
2 Question Groups:
1. I believe the ONT will be installed outside next to the electric meter, where the current phone line comes in. Close to where the gas line comes in. The "wireless router" (Acteck?) will be installed inside. The question is, just where the inside install would/should be. The ONT will be on a wall of the built in garage. This garage has one vent, so it never freezes, but the temps swing pretty much. The other side of the garage is the house laundry room, inside of which is where I have the current cable modem, router, 24 port switch and patch panel. ONT wall to patch panel is about 26'. I plan to run cable in the ceiling between the two points.
-How is the ONT connected to the wireless router? Coax? RJ-45? Something else? Choice of methods (which is best?)?
-There will be a UPS for the FIOS router. Does the ONT need power also?
-Will they want to install on the inside of the wall where the ONT is, or is 26 or so feet away ok (better wireless coverage & temp control)?
2. The fiber run from the street to the expected ONT location will likely run thru a fence gate and under a brick patio. Loosely placed bricks, no big deal, about 15' wide. I have been told the installers for the buried fiber will show up about 2 days in advance, when I'm not home, to make the run to the house.
-Will the installers just remove and replace the bricks as they run the fiber under it?
-Will they expect me to remove the bricks and leave a clear path to the wall for burying fiber to the ONT?
-An option might be for me to run a conduit from near that wall under an adjoining shed over the bricks. Good/bad idea?
Yes, I'll be calling the local office in an attempt to get these answers, but so far everyone I've spoken with has pulled a SGT Schultz on me ("I know Nothing").
Many thanks for any assistance you can provide. With other commitments, I'm running out of time to prepare for this install.
2 Question Groups:
