I rented an AcuTrac 3 for the installation of some AU-9S dishes. While I had it, I'd figure I'd align my AT-9. Using dithering, I've peaked azimuth and elevation. However, when I adjust the tilt, I'm way out there. I'm supposed to have 75 tilt and the best signal I have is as low as the tilt will allow (40). The elevation is roughly correct and the azimuth, well, it seems pointed correctly , but it's hard to use a compass to align a metal structure. On 13v no 22 kHz, I'm in the mid 80s. When I switch to 13v 22 kHz tone, I can't really beat 61 high 24 low and that is way out of where it's supposed to be. When near 75 where it's supposed to be, it's 49 high and 22 low.
oh, and there's condensation inside 2 LNBs (the outer ones) and a small puddle inside the middle LNB.
