DarrellP
Then you need to see HDNET from Dish, it will blow you away.
And what exactly do you disagree with? Have you seen HDNET from Dish? If so, what exactly is wrong with it? I would like to know because if you have any issues with HDNET via Dish, I have an inside source that I am working with to make sure it stays good.Vreesar said:Ofcourse there is always 2 sides to a coin and I completely disagree with DarrellP on this one
The INHDs and HDNets look pretty good on my Adelphia Cable, but certainly no better than VOOMs better programming. It depends what your Cable Co. is doing. A cable channel (6Mhz, QAM) has a max data rate of about 38Mbps. My local cable company is stuffing 3 HD channels per 6Mhz frequency (38/3 = 12.66Mbs per HD channel). It has been reported that VOOM is using an average of 12Mbps per HD channel. The ATSC standard for OTA is 19.39Mbps. IMO, a responsible cable company will transmit two (2) 15Mbps HD channels per frequency and use the remaining bandwidth for 2 SD channels.jeremys said:saw bikini destinations last night (and recorded it).
pretty good PQ. about the best I have seen so far. But, it's not like rush/equator are far behind.
Equator? You are kidding, right? What size TV do you have? I can see the artifacts on Equator on my 13" Commodore monitor using composite feeds.jeremys said:saw bikini destinations last night (and recorded it).
Both. They both still work, I have tons of programs for them.jeremys said:C-64 or vic-20?.
