Feature request: An emergency resolution button (unless I've overlooked it). I loaded 8/29 firmware into my receiver, rebooted and I thought I was at the reboot hang issue that someone had reported. I hooked up my composite cable and saw good OSD video (proving it wasn't hung). I traced things down to the 480i resolution (default in the new 8/29 firmware). 480i doesn't work with my HD set thru HDMI apparently - my HD set displays MicroHD video/OSDs thru HDMI in 480p, 720p and 1080i formats per my quick testing. once I set the resolution to 1080i, all was fine through the HDMI/my HD set combo. It got me to thinking there should be an "emergency" resolution button mapped on the remote - i.e. if you don't see video on your set, there should be a button on the remote that can be pressed to cycle through the various resolutions until hopefully you get OSD display or tuned video from the microhd. Composite video cable is a great backup option but takes a little longer to set up and use than a remote button would.
