I recently installed a corotor II on my 10' sami as many of you know.
It is supposed to have an f/d of .38 which according to sami spec sheet the focal distance is 45 5/8" from the center.
If I set my scalar on the .38 line with the feedhorn, I am not at the correct focal distance. I get decent signals.
I can move the feed inward toward the center of the dish where the signals come up significantly. But.......The f/d marking on the corotor is now between .32 and .34
Shouldn't this be at exactly .38 with the feed supports placing it at 45 5/8" to 1/4" inside the feed opening?
Should I set the scalar to .38 and then shim the whole thing in to the proper setting.
I know on the non adjustable ADL feeds that is what one member here said to do.
I would think the sidelobe rejection would be affected by the scalar not being the correct distance from t the feed opening for the specified f/d ratio.
What do you guys think?
