Can anyone confirm the proper crossover wiring connections to connect the AZBox with a PC?
I need to recover an AZBox through the back door and I don't have the proper Ethernet cable to assist in the project.
I looked up the Ethernet crossover pinouts on the internet, and I tried a couple variations, but there are multiple standards for a crossover cable cited. I need to know which standard is absolutely correct for this specific application.
This recovery process is unsure at best, but I must be sure that the cabling is correct first off. I can Google for the information, but there are too many variations out there on the web for different applications. I don't know which standard to apply for the AZBox-PC communication link.
I can fabricate my own cable, but I hate to waste too much time doing so. I just want to know the right pinout for the cable and then move on to other areas of concern.
Please understand that I cannot proceed with the recovery process of a failed AZBox with the uncertainty of Ethernet connection in the back of my mind, haunting me. I do have one working AZBox and one failed one. If I know that the cable is proper, I can troubleshoot my connection setup parameters with my good box and prove everything to be functional before I move over to repair the failed box.
Someone here must be using an Ethernet cable between your PC and your AZBox (not between your router and the AZBox). If you have a direct Ethernet connection between your PC and your AZBox, and it works, that is the cable that I need and I need to know the precise wiring of that cable. This would be a crossover Ethernet cable.
I would be very grateful to you if you can inform me of the precise wiring of that cable (which pairs are crossed).
Thank you,
RADAR
Thank you,
RADAR
