I'm now getting regular errors when transferring recorded programs, and I'm wondering if it's time to reformat the drives. Is that likely to help?
Here's the details: I have...
1) Hopper with Sling (which has, I believe, a 1.5 TB internal HD - the "total size" is listed as 1231GB, which I'm assuming has a partition that's dedicated for system stuff).
I have two external HDs connected via USB:
2) Ext HD #1 is a 2 GB drive ("total size" listed as 1882 GB)
3) Ext HD #2 is a 1.5 GB drive ("total size" listed as 1397 GB).
All of this setup is about 16 months old (ext HD #2 is older, re-used from previous Dish setup).
A couple weeks ago, I decided to re-organize the programs I have accumulated on my external HDs. After transferring a bunch of recordings back and forth, I've started to get errors ("an error occurred while transferring your files"), which causes the transfer to fail.
I can always delete recordings without errors.
I can always transfer recordings from either external HD to the internal HD.
When attempting to transfer recordings from the internal HD to either external HD, I can sometimes transfer a recording or two, but if I try and transfer more than a couple, I get errors pretty consistently. Sometimes I get an error even if trying to transfer a single recording.
All 3 drives are roughly 50% to 60% full, so I assume there's plenty of available free space for temp files or whatever else it needs during the actual transfer.
I'm wondering if one or both of the external HDs have bad sectors - it seems that read operations from the Ext HDs work reliably, but write operations to them result in regular failures.
I assume there's no way to "defrag" or map out bad sectors on external HDs directly from the Dish gear (please correct me if that's not the case).
I was thinking of doing the following - any thoughts?
1. Go out and get a (new) 2 TB external HD. I would use this to (eventually) replace my existing external EHD #2 (which is older and only 1.5 TB capacity), after shuffling things around. This would expand my storage capacity and give me new "fresh" space to move things to.
2. Disconnect EHD#1 temporarily (leaving Ext HD #1 out of the mix for the time being)
3. Connect the New EHD#2. At this point I'd have both New EHD#2 and Old EHD#2 connected
4. Transfer everything from the Hopper's internal HD to New EHD#2. This would free up all the space on the internal HD needed for transfers between external drives (the system doesn't allow copying directly between 2 external HDs, so to go from EHD1 to EHD2, it needs to go EHD1 > IntHD > EHD2). A bit of a pain, but just a bit time consuming.
5. Transfer all content currently on Old EHD#2 to the internal HD.
6. Once all the content from Old EHD#2 was removed, disconnect it and set it aside (to be reformatted and reused elsewhere).
7. Reconnect EHD#1. Now I have EHD#1 and New EHD#2 connected, each 2 TB.
8. Transfer all content from EHD#1 to the internal HD.
9. Disconnect EHD#1 and reformat it (via computer). Re-connect EHD#1.
At this point I'd hope that with 2 freshly formatted 2 TB external HDs, I should have no more errors when transferring, and I'd be free to move stuff around and reorganize as I like. That assumes...
A. The internal HD is OK (is there a way to map out bad sectors?)
B. The source of the errors was related to bad sectors or other issues that would be "fixed" by freshly formatting (in the case of the two external drives) or emptying and then filling (in the case of the internal drive).
Admittedly, this is a lot of hoop-jumping to do, but I'm concerned that (what I assume are) the write errors I've started seeing when transferring might be a sign of more intrusive errors to come. Hard drives are not perfect and they don't last forever, I figure doing the above would improve my chances of having trouble-free operations for a while and would preserve my recordings. Hard drives are not expensive, either (2 TB drives for under a hundred bucks are widely available, I can swing by Costco and grab one any day).
Does my plan above sound reasonable?
Any other suggestions?
Thanks for your insights.
