Ok....every football season I have taken the DTV box that's connected to the tv in the garage to my RV.
I use it for the TV that's in the outside bay where we watch games while tailgating. I have auto find satellite dish. The TV in the RV living area has a separate DTV box. I recently had DTV come out a they changed/ upgraded all of my home boxes, so the box in the garage is new and different from the one I had previously been connecting at the RV. As always I took the cable from the satellite in the bay and put it in the cable in connection, and plugged power cable into box, there's has never been a SWM switch used with this setup and I don't have one In my garage. I turned on the DTV box and the TV.....and get error code 775.
I look up the code and follow instructions, disconnecting and reconnecting cable. Again no SWM switch involved. The TV in the RV living room is on and working correctly with the satellite.
Thinking through the issue I open the door on the DAtV box and did a reset, no help.
Next I go to menu and select satellite, it says pick type of dish, you know all of the options I'm sure like 3 LNB round 18" or 5 LNB or Slimline (which mentions SWM). There are about 18 choices! Ok! I try every one of them so the DTV box is is looking for the satellite with the progress bar at the bottom of the screen. Only to get message satellite not found!
Can someone please help me with this issue? Why one DTV box inside sees Satellite and new DTV box outside does not?
