Back on the subject....in addition to checking fittings/resetting receivers/bypassing SWM splitter as Kirk suggested...you can take the power inserter out of the loop also. One receiver will power the SWM lnb to determine if the power ins. is the problem. Run line from the wall straight to the receiver, jump the splitter with a barrel, running straight to the dish.
THIS, I was not aware of ... I always heard that a regular recvr would NOT have enough power to run a SWM set up, I would remove the PI and the SWM LNB and use the old LNB to test with, if he still has it, THAT would work with the recvr powering the LNB.
The protection plan works well I guess for those folks who have an intermittent problem that sometimes requires multiple visits/different techs. Tech goes out..things are working fine..he changes a couple of fittings, peaks the dish-hoping he's found the problem and prevented a service-on-service chargeback....the most expensive kind and then BAM in a month or so the problem raises its ugly head again. Don't know for sure but I suspect customer gets charged for subsequent visits. Someone correct me if I'm wrong.
The IV retest program that is standard procedure on upgrades and service calls will head off service calls and result in better system reliability for customers. Eliminates a techs ability to "trick" a setup, allowing activation of new receivers on less than optimimum operating systems. Amounts to a free tuneup for customers. Sucks to a degree because you are not getting paid for the time required to whip things into shape. It is what it is.
And to think, awhile back we had techs here stating that they were required to check ALL RECVRS and to maintain the entire SYSTEM before they leave .... Which is it, your not getting paid to maintain the system or you are ?
