Hello,
Recently, I am having problems with my 119 signal. I get the 002 error on a lot of channels. Ran check switch many times to no avail.
Here is my setup:
(2) total receivers 3700, 4800 IRD connected to a SW64 swtich. The switch is connected to a Dish 500 (110 & 119) and another dish for 61.5 satellite. All LNB's are dual so that I can get all (3) satellites on both receivers.
Signal strength is around 90-100 on 119 (depending on what transponder I choose). Check switch test results in all OK except for 119 ODD.
When I get the error 002, it lists the transponder number. Am I supposed to get a good signal on EACH transponder??
ANy help would be greatly appreciated.
Thanks in advance.
Here is my setup:
Thanks in advance.
