Equity moving channels around
Mr Tony
2,755
12,087
Mankato, MN
Noticed last night there were some changes to the Equity channels
11799
KWBS was always in the mux (between KWBF and WBMM), but lately has been WNYI (52 Ithaca). Well, now its changed again.
KDEV-CA 62 Aurora is now here. But still shows on the guide as KWBS
It has moved from 11719 (2nd channel in mux).
That spot is gone (on the Viacast it goes from 1001 to 1003)
WNYI spot that was on 11719 is now KQOK-30 Univision Oklahoma
They did some more changing (again)
Jim
Rescan 11799. The spot where KWBS was (between KWBF WB and WBMM Daystar) is now KDEV
They replaced KDEV on 11719 with WNYI (at least thats what it logs in at) but its Univision?
This is weird.....
I watched the "top of the hour ID" on WNYI (2nd channel in 11719 mux) and it says "KLRA-LP" which is the first channel in the mux
Maybe they're keeping it warm?
11799
The legal ID on Lick TV that I get has changed to strictly KDEV-CA 62 now. I'm guessing that WPXS/KUMO are splitting off to Daystar.
The Mediacom/Cox legal was taken off of it as well, and no reference to WNYI was made either.
not necessarily
WPXS 13 still has Lick TV....at 9 Central and it ID's as the old stuff
WNTI 52 Ithaca
KDEV 39 Aurora
Cable 4 Holister/Branson
Medicom cable channel 4
WPXS 13
KUMO 51
Just saw it last night.
Scan 11799 again Jim
It is the 7th channel in the mux
WBIF, KTVC, KQUP, WMQF, WUMN, KWBF,KDEV(I think it still logs as KWBS)
I just saw it last night :)
The problem is, unless you see the ID's nothing really changed. It went from KWBS to WNYI to KDEV with the same video but different ID's :)
Diamond Jim said:
Okay, I will try that. Is WNYI a spanish station? When it popped on in the KDEV slot it had a latin looker on and she was rattiling off spainsh nobody's business. The 3688 showed a WNYI ID.
I think its just there to "stay warm"
The ID is KLRA, which is the 1st channel in the mux
Diamond Jim said:
Tony,
When I scan 11799 I get, in this order,WUMN, KCBU, KPOU, KUTF and Daystar.
All are spanish except KCBU and Daystar.
It should be the follwing
WBIF-UPN
KTVC-UPN
KQUP-UPN
WMQF-FOX
WUMN-Univ
KWBF-WB
KDEV
WBMM-DAYSTAR
WGMU-UPN
WPXS-LICK
KCBU_Jewelry
KPOU-UNi
KUTF-Telefutura
KWBM-WB
DAYSTAR
This is how it logs in on all 3 receivers
Found it. If I was with Red Foreman, he would ask "what kind of dumb**s are you. :yes " I put on KWBS and low and behold up came the LICK TV KDEV station ID. Had it all of the time, just labeled wrong. As I said "dumb**s :yes "
Thanks 'Berg.
no problem :)
Yeah, its changed 3 times but still says KWBS...even though that call letters is at the FCC (Equity turned that in) :)
As far as that goes, Mediacom Cable is taking the KDEV-LP feed. All I see at the top of the hour most hours is KDEV-CA 62 Aurora. (what's funny about that is there's an Aurora Missouri in my market as well!)
PANSAT 2500A program
Found IA 5/KU
