Okay my Inlaws have just put in a pool. it was wired properly to code. the Dingus electrician says you have to have a ground fault breaker. While this is true for most water things like a tub for a pool it doesnt apply... why? because it is not only naturally grounded but the ground from it is bonded to the house. So with the ground wire connected you turn on the pump and the breaker blows instantly. why? well its groundign out... as you have to wire a pool that way. So this dingus wont replace it with a regular breaker and wont call to get it inspected... so... i need the NEC code for pool wiring.
Could someone point me in te right direction?
Oh and for the record if you unhook the ground from the pump to the pool (Not pump to house ground) it works just fine... as it should... but those 2 do have to be grounded together to avoid static buildup.
