Edit channel on Fortec Mercury II ?
PhilipPeake
47
After scanning G10 I have one or two chanels with no sound. Isuspect that the audio PID may be incorrect and so want to add/change it.
However, I cant see how to do this. The "Edit Channel" function is practically useless, all it can edit is the name, position in the list etc.
I could delete it and use the "Channel Add" function, but this seems like a very long-winded way to achieve the result.
Anyone have any ideas?
(I looked at Channelmaster, but the Mercury II isn't listed amongst the supported receivers.)
I haven't used it but there is a channel list editor on the fortec site.
Be warned it is a clunky channel editor IMO that they offer. Took me a bit to figure it out.
would they happen to be KEYU & KAMT?
If so, thoise are AC-3 audio so you need a compatible audio receiver to hear them :)
Changing the PIDS wont do anything
The only way I have found to edit PIDS on the Mercury II is to delete the channel and then use the "add channel" feature. Of the three reciever brands I own, only my Satworks allows me to manually edit PIDS.
I have been trying to add a channel to my Mercury II and the receiver is changing the transponder frequency from Ku band to C band when it saves the information.
Has anyone else had this happen? My brother also has a Mercury II and his changes the frequency to a different Ku frequency than the one we are entering.
The weird thing is, sometimes the channel works on mine even though it shows a C band frequency, but other times it doesn't.
Had to reset receiver - now getting LOTs of channels!
Analog KU questions
