I'm sure someone can explain this one to me, so here goes. Got the dish(30") mounted yesterday then ran out of daylight. Today hooked the receiver (Pansat 3500) to the lnbf adjusted the elevation to pick up Echostar 9 which from reading it has a strong signal. Slowly moved the dish and and it came right up with 85% quality. I thought WooHoo!!!!!. This is too easy. Alright im off to another one. Changed the receiver to start at the top with T5-Ku. Slowly moved the dish again and the quality shot up to 85% again ( didnt touch the elevation). Man! This is easy. Right after that it all fell apart. T5-Ku had the same stuff as Echostar. So are they that close or is it a bleed from Echostar? From what i could tell they are quite a distance away. After that i tried a few different satellites and couldnt get a thing after moving the elevation and azmuth (except for that Echostar which i can get with no effort ,but does nothing for me). So someone give me a hint of what i can change to get T5. Also with a dish motor here is a quick question. Lets say I start wth Echostar as a refence with the motor hooked up could i use that as the reference point and find the FTA stuff from there.
Mike
40.57 - 81.39
Mike
40.57 - 81.39
