Launch date for E-15 is now listed as July 10, 2010 which could mean that E-15 could be operational by mid August. E-14 definitely looks like it will be operational before D-12 but will E-15 as well?
:up :up
Great News!
They are pushing it right along. E15 payload (fuel and satellite) is ~ 500 kg less than E14. If they use the full capability of the Proton/Breeze M, the release will be much closer to Geo, speeding things up significantly. Add that to the lack of spot beams needing testing and the decision to immediately position it on station means it might be up and running by Aug 1.
I am still a touch confused. If E15 is all CONUS beams, and they are moving CONUS HD currently located on 61.5 to 72.7, what programming will be on E15 at 61.5?
Good to hear it is being launched soon, though.
Hmmm...and the migration of core HD from 61.5 to 72.7 is on hold until further studies
My memory of your post says it's 4. 17, 19, 21, and 23.If memory serves, E12 could convert 3 more TPs to spot beam.
I believe the primary problem is power on E-12 but a lot of the power problems should be alleviated once E-15 is operational and relieve E-12 of all CONUS TP responsibilities. There have been questions whether TP 17 is functional at all E-12so this would be a loss of spotbeam capability.
Dish may decide to punt the spot beams until the replacement for E12 is launched. They may want to see if the launch is successful and use E12 as the backup plan in case it is not.
I suspect they will compromise and use a couple for LiL and hold the others for a backup plan. This would give them some power margin and not have to build more uplink centers. The uplink issue is probably more of an issue than power, considering they have 15% of the spots never to be used (point out west), plus some that the capacity will not be needed.
Dish will be in the position of too much capacity on EA right now (compared to WA). Until WA is converted to 8PSK, they may just have a lot of dormant capacity.
As designed, there was 130 spot beam transponders on E12. However, 29 are pointed at west coast locations, and I doubt need used. That leaves us with 101. I recall each one needs 65 watts of power. That is 6,565 watts. Another way of thinking about it, there are 33 SB TPs in the unused spot frequencies that can be used. That is 2,145 more watts of power needed.
However, only TPs 19, 21 and 24 are left on CONUS. I may be wrong, but I think turning those off only net 405 watts.
Do we know how much power is available on E12, given the failures? If they are tapped out, I think we might only see one of the 4 converted.
