Western arc as well.I'm in Lebanon and the only thing I've noticed is some occasional stuttering/pixilating during Game of Thrones on Sunday night.
While it may be level/plumb, it sure looks like it isn't aimed right.I checked to make sure the dish was still level today and it is. Still getting (35 to 37 on 61.5), (8 to 10 on 72.7) and (43 to 45 on 77).
If all the hardware is sound and there are no LOS obstructions (including condensation in the feed horn lens), I'd say that your elevation is probably out of whack.
Don't forget to check for a leaky (or otherwise obscured) LNB lens. Getting the outer slots without getting the one in the middle is not easy to do.Odd its been working fine for years.... I will take a look at the connections and adjust elevation a tad and see what happens.
Thanks I will check that if it ever stops raining...I will bet that the middle lens (72.5) is full of water. You can Crack the lens to drain water out and restore signal, but it will not last long.
I have the LNB off there is some water drops inside the middle 72 lens. Any way to get the water out without cracking the lens? Wouldn't that just let more in?I will bet that the middle lens (72.5) is full of water. You can Crack the lens to drain water out and restore signal, but it will not last long.
I ordered one from eBay thanks. Easy fix.I agree. Will be working in Columbia next week. PM if interested in a service call. Or just buy one off of eBay or Amazon
