I have installed my own equipment for years since my first DISH back in 98'....I need to switch over to Eastern Arc because of a very large oak tree that is now blocking 110 and gives a low signal during the summer with 119.....My questions are....
1) When peaking the signal which location should you do first? second? third?....
2) Which transponders should you use to peak each location?
3) Should I run a direct line for each location to the 722 directly to peak signal or can I go through the 4-4 switch?
Thanks Very Much
Thanks Very Much
