I've been digging through the threads about Eastern Arc and I realize there is nothing to be gained for standard channel SD quality (480x480 MPEG4 at a lower bit-rate than 540x480 MPEG2). I'm curious if there is any advantage for the sports packages, in particular NHL Center Ice.
The HD feeds provided via Center Ice often look great -- the problem is there is still a significant number of games still broadcast in SD. In MPEG2 on my 110/119/129 configuration some of the SD games are barely Youtube quality -- significantly worse than any other SD channel I get from Dish. Is there any possibility the MPEG4 feed on Eastern Arc would deliver anything better?
