eagle aspan
mrski57
29
what do you pros think of the eagle aspen one wire system rotor? thanks!
The Eagle Aspen Rotr100 is a decent light / medium duty remote controlled rotor. The unit uses a hall sensor alignment system to ensure aim accuracy consistently within 2 degrees. The drive unit is otherwise typical of the other Chinese made drive units with plastic drive gears.
I would not recommend using the coax cable for both the antenna & the drive unit unless all signals are relatively strong. While I have no personal experience with this model, I would consider buying one because of it's consistent accuracy capability if & when my present rotor fails.
Eagle Aspen Rotr100
Installed 3 weeks ago, single RG6 <60feet and 30db UHF antenna amp. Works good for me, would rate 8 of 10. See my thread in FTA or maybe ICE will move it here.
Considering a new TV - any have PVR built in?
NYC and Allentown in Philadelphia?
