During a recent storm, a nearby lightning strike apparently fried the two LNBFs on my Glorystar system (one of the earlier models, with support for SES1 and Galaxy 19). I had long planned transitioning from the two SL1 LNBF system (with the SES1 LNBF no longer used) to a single dual LNBF dish (to allow multiple receivers). Being short on cash, I ended up getting an ESX522 (which was less than half the cost of an SL2).
At first, all went pretty well. Both my DVR1100c and the Viewsat VS2000 Ultra which I added were working well. Then I noticed a couple times when I booted to DVR1100c seemed to lose some channels after power up that the Viewsat saw just fine. Finally, the DVR1100c lost the channels permanently.
I tried switching LNBF inputs, switched wires, reloaded firmware... nothing. The Viewsat saw everything, while the Geosatpro was missing a bunch of channels. One channel, JN1, actually shows adequate signal sometimes according to the Signal display, but remains black.
Then I noticed the pattern -- I lost all the Vertical channels. The Horizontals are just fine. Given that I've swapped everything I can readily swap, done OTA loads, and even reloaded firmware from the USB, I've come to the conclusion that the Geosatpro has likely fried the circuitry needed to switch between Horizontal and Vertical.
Sounds like it is time to purchase a new receiver. Anyone have an alternative which I have not considered?
