I know its probably been discussed before, but I want to make sure I understand this correctly. If I use an external drive with a 211 hd receiver will I have all the same functions as a regular dvr, such as setting timers for recordings and having the extended multi-day guide? Or am I limited to doing basic manual recordings and archiving of programs?
Also, are the new vip boxes backward compatable with a DP500 and DP300 dish connected through a DP34 switch? I have the ability to get 110/119/129 now with the 2 dish setup, would the install guy want to swap it out for a 1000.2 or would he likely leave well enough alone? Is there any advantage to using the 1000.2 over the setup I have now, other than the convenience of a one dish setup? Which is better for signal strength and rain fade resistance?
