DVI Cable
Wells there's dual link DVI-I and Single link DVI-D, actually you can probably
use both but they recommend the DVI-D. DVI-I is used for computers where
infomation has to be transmitted back and forth thru the cable. DVI-D is one way transmission. The difference a person would notice is in the pins in the connectors, in a DVI-D there is a open space in the middle of the connectors
were on a DVI-I there are pins thru out the connector, if there is nothing in
the 811 or your TV were the DVI-I connects (that is inside the units there's
no electronic ) then it really doesn't matter the pins just connect to nothing.
The Phillips cable is a DVI-I (Walmart) Monster's are DVI-D. I personally had
some problems with the Phillips cable, causing my screen to go blank and come back on, it was a problem with the TV's connection not the 811. By
the way componet cables work just fine too. In my opinion the DVI a tad more brighter,use to have less color saturation then componet until the 269, or the 280 software update. Wow sorry a bit long winded.
