Here's an odd one I just encountered.
I have this large job of DVD duplication. Several thousand.
I burn the DVD's in a tower and then stack them in a Print Factory II from Microboards. The disks feed one at a time perfectly, sometimes two in the stack. But if I do more than 10 in the stack they don't drop like they should.
Tech support said it is likely the cartridge, swap it out. Maybe you have a bad batch of cartridges. He said that the cartridge has a sensor that prevents disks from dropping if there is a problem. He felt the connection for the sensor was intermittent.
So, as I sit here feeding the DVD's 2-3 at a time, I noticed the DVD's were sticking to each other in the stack plus the hair on my arm was standing up. Why? static electricity! When there are a large number of static charged disks above the one next in line, the charge won't allow the disk to drop into the alignment hopper.
Besides building a metal table that is grounded to sit the disks stacks on waiting for the printer to bleed off the charge in each disk is there any other way to fix this?
Normally, you wouldn't suspect that static electricity would be a problem in humid Florida in the summer, but it is when the disks are spinning in the burner at elevated temperature which will charge up the disks. Putting the disks in a stack for printing, just works like putting cells in a stack to make a battery. The charge increases.
I think this also explains why when I get ahead on the burn time and have disks waiting these will print just fine in a stack. It gives the disk stacks time to bleed off the charge.
