SOLD!! DVBS S2 Signal Meter w/Spectrum Analyzer & TV Monitor - $100
Titanium
AI6US
7,665
9,095
Meadow Vista, Northern California
For Sale: Fujitsu S2 Satellite Meter
Based on the SatLink WS-6912 model - DVBS S2
Great Condition - Factory Sample evaluation unit with less than 10 hours use
Accessories:
- 2700mAH Rechargeable/replaceable Battery
- 120Vac Charger
- Working/Carrying Case, with Shoulder Strap
Displays TP frequency, Polarity, Symbol rate, Service Name, Service PIDs, CNR, BER, Strength in dBm or dBuV
Signal Quality Tone On/Off
DiSEqC and 22KHz Switch Control - Manual Setting or Auto Detect
DiSEqC 1.2 / USALS Motor Power and Control
Blind Scan/ Pre-programmed TP List / Single TP
Manual Satellite and/or TP Entry
Multiple Transponder Monitoring (for balancing or cross pol adjustment)
North American Satellite List
Dolby / AC3 Audio Decoding
QPSK / 8PSK
Supports All Universal and Standard type LNB LO Frequencies Including User Custom Setting
15 Languages
Internal Compass
Ability to DVR to optional USB drive
AV Input (RCA)
*Can email the loader and editor PC application
IMG_4915.JPG IMG_4916.JPG IMG_4917.JPG IMG_4918.JPG IMG_4914.JPG IMG_4913.JPGIMG_4919.JPG
Interesting. How much lag does it have between a dish adjustment and the change being reflected on the display? How visible is the screen in the sun? Is there a link to a manual somewhere?
- Trip
Meter response is almost instantaneous and just as fast as any other meter or current model STB. The screen is best viewed under the case shade cover. Visible, but much easier to see under the cover. No manual, but it is very easy to navigate and functions are via GUI menu set-up.
The unit displays programming from DVBS and S2 services with Dolby/AC3 audio.
It is from the factory that produces the Satlink branded meters. I have found that the Satlink 6912 model functions and features most closely match the unit.
Dang if I had 100 dollars burning a hole in my pocket.
Does it come pre-loaded with a sat list?
Is the software easy to program?
The "watch TV" work?
Yes. Pre-loaded American satellite list. Easy to add, edit or delete satellites, transponders and channels.
Press the view button and watch TV or listen to radio. All STB features found on most receivers plus the meter functions.
FOR SALE Two 17/10 Emp-Centauri Satellite multiswitches $160
Summer Time Clean Out (DVB2 / Dish Network)
