Hi Just received, 6/23/2010, the DVB HD 2104 USB box from Sadoun. I also have the same receiver, but purchased last summer. The new box ran fine with the April 13 2010 software. However when I tried to install the May 28 2010 software, I received the following error when starting
"DVB World.exe":
DVB World
Fail to init device, please check it!
Do you want to try again?
Yes No
Using Microsoft's device viewer UVCView.exe (found in the WinDDK folder) it indicates:
---===>Device Information<===---
ConnectionStatus:
Current Config Value: 0x00 -> Device Bus Speed: High
Device Address: 0x01
Open Pipes: 0
*!*ERROR: No open pipes! "
Plus 256 more lines of information.
Tried using the device manager to uninstall the driver then reinstall the driver. Tried both amd64 and i386 drivers. Only the amd64 installes but issues the following error:
A problem message (do not remember details) appeared then followed by:
"Windows cannot verify the digital signature for the drivers required for this device. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source. (Code 52)"
Checked:
1. power connection ok
2. usb connection ok
3. Works with April software; but no blindscan.
4. Disabled virus scanner (PC Tools) during software installation.
5. There is no indication of a 2010 "D" version. Marked the same as my older box, except for later serial number.
Using Windows 7 64 bit.
Any help is greatly appreciated, thanks
Rob
"DVB World.exe":
DVB World
Yes No
ConnectionStatus:
Open Pipes: 0
Checked:
Rob
