still only 3 birds
To flesh out the bandstacked idea . . .
Sadoun sells this
C-band bandstacked LNB pretty cheap.
Used to offer it with scalar, not sure why not any more.
We've discussed the Ku band Dish/EagleAspen FSS LNBs, and where to get them.
A surplus Dish DP-34 switch will take three LNBs and drive four receivers.
You can cascade two DP-34's to feed eight receivers.
You can cascade three DP-34's to feed 12 receivers.
Not sure what the limit is, but they are amplified, so you really should not have any problems.
You would need to set your receivers to all supply 18 volts (H) to the switches to run them properly.
Doesn't seem a big problem.
Cascading the switches requires three short cables between them.
I've gotten the switches for $10 at swap meets, or free on the way to the dump.
For the cost, effort, and complication, I don't see this way being much different from that outlined by Iceberg.
You
would have to make up three short RG6 jumper cables.
There is only one useful consideration that might make the bandstacked idea better.
You could get both polarities of all three birds at all receivers.
That's about it.
Oh, and it would be easy after-the-fact, to add a few more receivers.
Even so, I can't make a strong argument, for this approach...
. . . just talkin' to myself . . . -
