these are just some points i was thinking so some might be more questions ...
i was wondering if they are a good sat finder (DUAL ANALOG METER AT-1022)or.
i know the analog change is for OTA but with most everything going Digital i would be reluctant to buy anything with Analog in the name.
if i should get a Dual Digital Satellite Meter DSM-22LA?i want to buy a new meter
only place i found any information on this unit it listed
"- RG-59 jumper w/ quick connectors"
and i know everything has basically went to RG-6 so is this a older unit or is it using older parts??
i have 1 of those sat finders10-sf20 that makes a squeling noise you have to adjust with a nobe.
this might be the best of the three and cheapest.....
but if i picked a signal meter one of the sponsors makes them and a couple other sponsors sell several different models.
I can say this i did try one of the higher end models and it was basically a unit programed with a unique transponder for each satellite so it really wasn't a satellite identifier but it was a signal finder. but it was no better than a DVB receiver and a TV hooked up at the dish ( it was just a compact version). i did find it difficult to use the higher end signal/satellite finder and had trouble with the unit so went back to the receiver & tv version.... cheaper & easy for me to use . but is a nice compact unit and with the preprogramed unique transponder it will try to identify the satellite. great for someone doing a lot of installs.
also others to consider
Accutrac22Pro Dual Satellite Signal Meter
SATELLITE INSTALLER'S SIGNAL METER MODEL Sat Buddy 2™
SATELLITE INSTALLER'S SIGNAL METER MODEL Dual Buddy™
Trimax Meters SM-2200 Digital Satellite Finder Meter (higher priced )
the dual would allow you to align two lnb's on one meter ( if i read it right)
