OK there are 4 buttons you use
PROG
RF
SAVE
EDIT (the wheel on the right side)
To set it up for the type of signal (DC2) press
PROG
EDIT (push the wheel in...EDIT lights up)
turn knob it "DCII MANUAL"
then press SAVE
Now you are in DC2 mode. DVB is the other mode (normal FTA)
to program in a channel
press RF
select the sat input (1,2,3,4)...to change press the wheel in to light up edit. To change make sure EDIT isnt lit and then turn the wheel
press RF again
set the frequency, symbol rate and FEC (I leave it on AUTO FEC) (scroll to the item, press EDIT, then change)
press RF again
set LNB polarity if not slaved. LOW is vertical, HIGH is horizontal
Tone is OFF (unless you have a 22k involved)
L.O. is the LNB LO. You may have to set this first before you change the frequency in the 1st screen (if you have the wrong LNB LO)
Mode is weird. There are 3 DC2 modes
DC2C
DC2I
DC2Q
I know one works with 19510 symbol rates and one works with 29270. I forget which one
when that info is entered press SAVE. If the signal is there it will show yellow
press PROG and it will show MPG on the front screen
scroll to the far right, press EDIT then turn up or down. It will go through the SID # (so it may not be 0001). If the channel is scrambled the authorized will blink and thats it. If its clear the authorized will be solid
It may sound confusing but once you get the hang of it it really isnt that bad
