Does anyone have a DSR 920 they want to get rid of? Mine slide off the shelf dropped 6inches and now I get nothing but snow, the signals are good,is there a way to fix it, is it fixable? Thanks.
There was a discussion of repair shops a while back.
I suggest you search for the conversation to see what came of it.
One place they did mention was Professional Satellite Repair.
Whether it was a good place or a bad one, I don't recall.
Question,
1) Can you get a picture on your TV by using the option button?
2) Also make sure you switch is set to correct channel 3 or 4.
3) Remove all cables from the dish ..did you get a picture
Sounds like you may have damaged the F connector coming from the dish, try either a new cable or connector, the last option is you damaged the connector in the unit.
