DS-2177 - Winegard Dish with "D-Shaped" Arm - Which LNB?
Gary K
7
7
New Jersey
Hi:
I have two separate dishes for Anik - one at 82 degrees and one at 91 degrees. I'm wanting to increase the size of my dishes because of issues - I'm on the very fringe of the signal - and I'm going to order two Winegard DS-2177 dishes with the "D-Shaped" arm.
Problem is - I want to be 100% certain that the DISH PRO LNB is the correct one to order. What's very, very weird is that on the Solid Signal website the photo appears to show the arm upside down -- and this has me very paranoid.
The bottom line question: Is the DS-2177 compatible with the Dish Pro Digital LNBF?
Many thanks!
Dish: Winegard 30in DISH Satellite Dish with D-Shaped Tube (DS-2177) from Solid Signal
LNB: DISH Network Dish Pro Dual Output Satellite LNB (120810) from Solid Signal
It doesn't matter which satellite they're pointing at - Canadian or American - the issue is the relationship between the LNB and the Satellite. These same dishes and LNBs are used by countless more DISH users in the USA than in Canada. I'm trying to get an answer on the Winegard 30 and the LNB -- it has nothing to do with Bell.
And it really has nothing to do with Dish either, and this is a Dish forum, so.....
Not sure why everyone is making this so difficult... yes, wrong forum, but the answer is the same for DIsh or Bell...
Yes, the linked Winegard dish and the LNBF are compatible. The combo should provide significant gain for single satellite Dish or Bell service reception compared to a 18' / 24" dish.
Good luck with your project Gary K !
Reactions: pattykay
Gary K, please don't let the rudeness of a few users here chase you away. This is a good forum, and most of us are very helpful without being snotty or forum police.
To you others: A dish is simply a REFLECTOR, nothing more, nothing less. An lnbf is nothing but an antenna and receiver/pre-amp. Bell uses DISH based equipment. Pretty much everything that applies to DISH, applies to BELL.
Bridging on Hopper turns off
parttition an HDD on a hopper 3
