DPP44 only showing 119
tomdkat
92
I got my dpp44 hooked up with to sat dish inputs into port 1 and 2. I have one wire going out through the power inverter and to a spliter going to my 522. When I run the check switch in only shows the sat input number to at 119..... It does not show 110
unhook everything (coax from dpp44 etc.) remove power to power inserter, try a switch check... then hook it all back up and try again and see what happens.
If it truly is a splitter it will not work for the dual tuner, look at it and it should say separator, if it says dp splitter you got ripped off. or use tow lines to the 522
Newbie
322 reciever question
