I recently had been upgraded to D1000 and having a dish at 61.5, got the DPP44 installed as well. The switch was attached to the base of the D1000 and therefore exposed to the elements. I live is So Cal and the Summer days can get over 100f and the rainfall can be of decent amounts. So here's my question.... How is the switch when it comes to heat and moisture? Should I just let it be, or should I look at getting a weather proof box to install it in? I know the box won't help with the heat much, but if it's vented and the switch is out of direct sunlight, it might help. Now for the moisture, I'm even less in the "know." Is it better to keep it protected, or is it already protected?
Oh, I have a replacement unit I got off ebay for just under $100, so if the current one fails, I wouldn't be down for too long. Still, don't want to use it unless absolutely necessary.
Thanks!
Thanks!
